| Message |
I've been pondering this a little while and haven't quite figured it out.. Hypothetically, if you were to measure the shaft power required to turn a T04B 60 trim wheel to flow ~8psi and ~35#/min, what would that figure be? I'm thinking it can be theoretically calculated using the flow map which shows wheel RPM, efficiency, and using the pressure ratio and amount of air moved, it can be converted into a power figure. Anyone have some ideas?
[ ashleypowers.com ] [ agpowers@bellsouth.net ] [ Zemulator Information Sheet ] [ Z1 Motorsports Website ]
.JPG) Enthusiasts soon understand each other. --W. Irving. Are you an enthusiast?
